I have the following circuit in my breadboard. My intention is to split a +24VDC into +12VDC and -12VDC. I'm using MC79M12 with this datasheet for the negative output and UA7821 with this datasheet for the positive voltage output. My goal is to power a circuit with op-amps from a +24VDC.
I was hoping to get +12VDC at node a
and -12DVC at node b
to power the op-amps relative to GND. But the voltage source goes from CV to CC automatically and the voltage regulator gets heated pretty quickly (to the point of feeling it by the smell). I don't measure -12VDC at node b; in fact, I measure a positive voltage, which is pretty small. I can imagine that the regulator is maybe reversed-biased and I'd need a -VCC for it to work... but theoretically it seems plausible to work since my GND is the 24/2 = +12V.
I've connected the input pin of both regulators to the +24VDC input voltage; I've connected the ground pin of both regulators to the common ground of the circuit; I've connected the output pin of the LM7812 regulator to the positive terminal of +12VDC output I've connected the output pin of the LM7912 regulator to the negative terminal of -12VDC output. Finally, connected loads and capacitors as suggested in the datasheet (I took into account the polarity of C4 and C5, which have + side to the GND).
But it is not working. What am I doing/thinking wrong here? If it is not possible doing it this way, how could I split the +24VDC into +12VDC and -12VDC?
Thank you very much!
