I want to buy a linear solenoid that has the following specifications in the Datasheet:
- 24 VDC
- 9W 100% Duty Cycle
- 18W 50% Duty Cycle
- 36W 25% Duty Cycle
- 90W 10% Duty Cycle
And the following force-stroke curves:
I have a power supply of 24VDC and 10A. Since I don't know the coil resistance (at 20 °C), how can I know the current that would go through the coil?
In other words, do I have to assume that at 24V the curve that represents the behaviour of the solenoid corresponds to 100% duty cycle and 9W? And the other curves are only for higher voltages than the rated voltage of 24 V?
