Question
Is there a temperature sensor (or else) which allows for the measurement of a copper pour on a PCB (and therefor the approximate temperature of a component)?
I want to read the temperature via an ADC (due to firmware complexity) to provide telemetry and shut the system down when the temperature reaches a certain threshold. It needs to be consistent and quick enough to be useful, and I realize accuracy will be limited.
Background
I would like to know how hot my MOSFETs are getting. They use SMD packages, and im cooling them through the PCB with a heatsink and a fan on the other side.
My main issue is that it seems to me that most SMD temperature sensors are geared for ambient temperature measurement. I cannot connect any of their pins electrically (and thus thermally via the copper pour) to the hot part, and it would be too expensive for my application to add thermal jumpers (not that I know for sure that a strong thermal connection to the pads would yield a good response time)
It feels like my best bet could be to just place the temperature sensor (example) really close to each MOSFET's tab, and surround it in a copper pour. Perhaps doing something fancy like a comb pattern between the MOSFET's pour and the pour on the sensor's pins to increase surface area
The fact that this seems to not have a lot of questions about it (that I could find), or products that do this (that I could find) makes me think my approach may be wrong, or that im searching in the wrong place. Perhaps with a heatsink, the temperature differential would be slow enough to not need a strong thermal link?
