Background
In this question, user @glen_geek posited (with linked references) that perceived light from an LED versus actual light from an LED is greater at lower duty cycles:
@kando For PWMing LEDs, people.csail.mit.edu/jstraub/blog/How-to-dim-a-LED-for-humans suggests that half-brightness occurs at about 8% PWM in the 2nd-to-last graph.
For perceived brightness non-linearity, you might try: pathwaylighting.com/products/downloads/brochure/…
Possible Clarification
I assume that the plot of specific constant duty cycles (in 100 [ms] periods):
is not correlated to the figures of the dynamic cycling duty cycle (in 200 [ms] periods), as this would require the actual duty cycle period to be order(s) of magnitude smaller to achieve any precision in the dynamic duty cycle being discussed:
Question
If the eye amplifies light for smaller PWM duty cycles at cycle frequencies which are much greater than the perceptible flicker rate (>>200 [Hz]), could an LED be made more efficient (in terms of perceived intensity vs input power) by only operating at lower PWM duty cycles?
