I want to drive several irrigation solenoid valves with solid state relays. The solenoid in question is a Hunter model 606800 24V AC device. Its specifications state 370mA inrush current and 210mA holding current at 24VAC 50Hz.
I've looked at many SSR spec sheets but on none of them can I see any mention of any issue when driving an inductive load. For example this SSR: https://www.farnell.com/datasheets/2144238.pdf
So will such an SSR drive an inductive load like a solenoid?
Edit: would a symmetrical Transient Voltage Suppressor be a good option? Across the solenoid or the SSR?
