I have three AGM batteries (VARTA LA95, 12V, 95Ah) that I want to connect in parallel in a battery bank.
They were connected to a Victron charger for a long time and now that I turned it off, I began reading the voltage daily just for fun. They were all connected to the same charger output.
One of them is clearly behaving differently, but I can't figure out what that means.
My question is:
  • Is battery #3 "healthy"?
  • Bonus question: What happens if I use it in parallel with the other two?
timestamp batt #1 batt #2 batt #3
t0 + 24h 12.90 V 12.83 V 12.51 V
t0 + 48h 12.90 V 12.83 V 12.48 V
t0 + 72h 12.90 V 12.83 V 12.45 V
t0 + 96h 12.89 V 12.83 V 12.43 V
t0 + 120h 12.89 V 12.83 V 12.40 V
(t0 is when I removed the charger)
  • \$\begingroup\$ To answer your bonus question: Don't connect batteries in parallel unless they've been charged in parallel (or by a charger designed for that use case). \$\endgroup\$
    – Sneftel
    Commented Sep 1, 2023 at 14:06
  • \$\begingroup\$ These ones were charged in parallel and they all are the same model, so I expect it to be fine. I was only surprised to find that one of them looses charge much faster than the other two. But they were all bought used and from different sellers... \$\endgroup\$ Commented Sep 5, 2023 at 8:42
AGM batteries have a self discharge rate of 1%-3%/month Assuming for the moment that self-discharge will be linear with time (probably as a worst case), extrapolating your 120 hours to 30 days, shows battery 3 to fall within the 1%-3% range.
  • \$\begingroup\$ That's a good way to look at it; I forgot to estimate the self-discharge. But I get a rate of over 5% for battery #3 and less than 1% for the other two. It's probably better to replace it. \$\endgroup\$ Commented Sep 5, 2023 at 8:49
Nothing spectacular will happen, maybe tiny sparks when connected together, and then they will even out. The batteries will work as one unit.
  • \$\begingroup\$ This got me thinking and I suppose what will happen is that #3 will slowly drain from #1 and #2 and the whole SoC and voltage will be a sort-of-average of my values in the table. And the sparks will be due to the current flowing into #3. \$\endgroup\$ Commented Sep 5, 2023 at 8:52
