It has been nearly universally the case that the cable which connects an external power adapter (power supply) to a laptop computer is permanently fixed to the power adapter. This makes the cable more or less un-replaceable. Being so, if/when the cable fails, an entirely new power adapter must be purchased.
This is in contrast with phone chargers, which, at least for Android type phones, almost universally have a detachable, and hence replaceable, USB cable between the power supply and the phone.
In my experience, lap-top power cables fail far more frequently than the power supply itself. Having a power supply with a detachable cable that could be purchased separately would seem to be something that would reduce the total cost of ownership for end users, even if the initial cost might be more.
A possible explanation might be that the manufacturers make good money on replacement power supplies, and are relatively unconcerned with the total cost of ownership for the end-user. But that would not explain the absence of such products in the replacement market.
It has made me wonder whether there is some (perhaps not very well considered) regulatory obstacles for the heftier power supplies for lap-top computers that do not apply to the smaller phone chargers. It occurs to me that there may be safety or EMI regulations that make detachable cables for larger power supplies problematic. However, I find it hard to believe that a male or female connector physically integrated in a power supply would pose any more "danger" or EMI issue than the same connector on the end of a cable.
My question is, are there any regulatory reasons or possibly technical problems that militate against a "USB cable" type model for lap-top computer power supplies? (Obviously, USB itself will frequently, not be up to the task in terms of power.) Or, is the lack of lap-top power supplies with detachable cables on the low voltage side merely the result of suppliers having little incentive to reduce total cost of ownership?
