I have an audio amplifier and one of those cheap Chinese Bluetooth audio receivers.
The output of the receiver is way above audio line level, about 7V peak to peak.
When using that as input for the amplifier, it starts clipping.
Now, I could just attenuate the receiver signal with a resistor voltage divider or potentiometer to 1V peak-peak line level.
However, I was wondering what would be the simplest way to attenuate a signal of arbitrary level (say somewhere between 2V and 10V peak-peak) to a fixed 1V, ideally without opamps?
