I have led headlight with 3 AAA batteries. I will rather have similar device use 1 AA battery, even if it will be more expensive. But seems there are no such devices. Why?
I've got the question after watching https://www.youtube.com/watch?v=4alV5LzHLE4 and later I've found Least expensive way to boost DC voltage where charge pump is also mentioned.
How expensive can converter from 1.5 to ~5V be if mass produced? How small by volume and weight? TIA
TL;DR
As I've understood from mentioned QA there are limitations to charge pump. Namely only 2x raise and some issues "under load". How much load is LED? I've just tried to use my headlight with only 2 AAA and light is much dimmer (I recall there is optimal voltage to LED); ok, producer may insert bigger LEDs to compensate for that (I don't recall efficiency drop is voltage is reduced, or is it? *
). Or maybe solutions to raise from 1.5 to 5 are also cheap is mass produced?
When searching for efficiency of LEDs found How can I efficiently drive an LED? where graphs are mostly vertical.
Now found https://www.candlepowerforums.com/threads/why-3x-aaa-batteries-in-stead-of-1x-aa-battery.364897/:
The 50 cents for a boost circuit might seem like nothing, but on a $3 flashlight that would wipe out any profit.
If true I will gladly pay $1 higher price knowing I'll save much more on batteries. Really almost nobody else will?
andHow much load is LED?
... they cannot be answered with one answer ... the other questions about price are off topic here \$\endgroup\$
