I tried to manually setup a STM32 project for my nucleo board, however the binary behaves strangely during compilation. The current project state is located in a github repository.
I noted two problematic items, but I don't know if they are related:
When I set a breakpoint in the entry point function, "Reset_Handler", with gdb-multiarch, the breakpoint is never reached, and the debugging session breaks in a random function:
Checking the objdump of the binary,
arm-none-eabi-objdump -D build/stepper-driver.elf > stepper_dump
, I noticed a mismatch between the addresses of the handler functions and the values stored by the vector table:
Vector table:
08000000 <g_pfnVectors>:
8000000: 20020000 andcs r0, r2, r0 # equivalent to .word _estack
8000004: 08000389 stmdaeq r0, {r0, r3, r7, r8, r9} # equivalent to .word Reset_Handler
8000008: 08000257 stmdaeq r0, {r0, r1, r2, r4, r6, r9} # equivalent to .word NMI_Handler
800000c: 080002b9 stmdaeq r0, {r0, r3, r4, r5, r7, r9} # equivalent to .word HardFault_Handler
8000010: 080002cf stmdaeq r0, {r0, r1, r2, r3, r6, r7, r9} # equivalent to .word MemManage_Handler
08000388 <Reset_Handler>:
8000388: f8df d034 ldr.w sp, [pc, #52] @ 80003c0 <LoopFillZerobss+0x12>
800038c: 480d ldr r0, [pc, #52] @ (80003c4 <LoopFillZerobss+0x16>)
800038e: 490e ldr r1, [pc, #56] @ (80003c8 <LoopFillZerobss+0x1a>)
8000390: 4a0e ldr r2, [pc, #56] @ (80003cc <LoopFillZerobss+0x1e>)
8000392: 2300 movs r3, #0
8000394: e002 b.n 800039c <LoopCopyDataInit>
08000256 <NMI_Handler>:
8000256: b480 push {r7}
8000258: af00 add r7, sp, #0
800025a: e7fe b.n 800025a <NMI_Handler+0x4>
080002b8 <HardFault_Handler>:
80002b8: f01e 0f04 tst.w lr, #4
80002bc: bf0c ite eq
80002be: f3ef 8008 mrseq r0, MSP
80002c2: f3ef 8009 mrsne r0, PSP
80002c6: 4671 mov r1, lr
80002c8: f7ff bfc8 b.w 800025c <HardFault_Handler_C>
80002cc: bf00 nop
080002ce <MemManage_Handler>:
80002ce: b480 push {r7}
80002d0: af00 add r7, sp, #0
80002d2: e7fe b.n 80002d2 <MemManage_Handler+0x4>
The addresses of the vector table is incremented by one of the correct values.
My current theory is that the execution of my binary starts from the beginning of the vector table, and the mismatch among the addresses caused the error described by the previous item (random function during the debugging session).
What's happening in the first error I described?
Does my theory make sense? (explained in first answer)
What am I doing wrong that's causing the addresses mismatch and how can I solve it? (solved - not an error)
Update
The addresses mismatch is already explained by a comment, however the initial problem still happens.
Update 2
Including the memory dump around Reset_Handler function
memory dump:
0x8000370 <SystemInit+60>: lsls r1, r0, #12
0x8000372 <SystemInit+62>: str r3, [r4, #112] @ 0x70
0x8000374 <SystemInit+64>: ldr r3, [r4, #0]
0x8000376 <SystemInit+66>: bic.w r3, r3, #16777216 @ 0x1000000
0x800037a <SystemInit+70>: str r3, [r4, #0]
0x800037c <SystemInit+72>: ldr.w r3, [r4, #140] @ 0x8c
0x8000380 <SystemInit+76>: bic.w r3, r3, #16777216 @ 0x1000000
0x8000384 <SystemInit+80>: str.w r3, [r4, #140] @ 0x8c
0x8000388 <Reset_Handler>: ldr r3, [r4, #8]
0x800038a <Reset_Handler+1>: bic.w r3, r3, #3
0x800038e <Reset_Handler+5>: str r3, [r4, #8]
0x8000390 <Reset_Handler+7>: ldr r3, [r4, #8]
0x8000392 <Reset_Handler+9>: bic.w r3, r3, #240 @ 0xf0
0x8000396 <Reset_Handler+13>: str r3, [r4, #8]
0x8000398 <Reset_Handler+15>: ldr r3, [r4, #8]
0x800039a <Reset_Handler+17>: bic.w r3, r3, #7168 @ 0x1c00
0x800039e <Reset_Handler+21>: orr.w r3, r3, #6144 @ 0x1800
0x80003a2 <Reset_Handler+25>: str r3, [r4, #8]
0x80003a4 <Reset_Handler+27>: ldr r3, [r4, #112] @ 0x70
0x80003a6 <Reset_Handler+29>: bic.w r3, r3, #768 @ 0x300
0x80003aa <Reset_Handler+33>: orr.w r3, r3, #512 @ 0x200
0x80003ae <Reset_Handler+37>: str r3, [r4, #112] @ 0x70
0x80003b0 <Reset_Handler+39>: ldr r3, [r4, #112] @ 0x70
0x80003b2 <Reset_Handler+41>: orr.w r3, r3, #32768 @ 0x8000
0x80003b6 <Reset_Handler+45>: str r3, [r4, #112] @ 0x70
0x80003b8 <Reset_Handler+47>: ldr r3, [r4, #8]
0x80003ba <Reset_Handler+49>: bic.w r3, r3, #123731968 @ 0x7600000
0x80003be <Reset_Handler+53>: str r3, [r4, #8]
0x80003c0 <Reset_Handler+55>: mov r1, r8
0x80003c2 <LoopFillZerobss+20>: movw r0, #3326 @ 0xcfe
0x80003c6 <LoopFillZerobss+24>: bl 0x8000298 <HardFault_Handler_C+60>
0x80003ca <LoopFillZerobss+28>: ldr r3, [r5, #4]
0x80003cc <LoopFillZerobss+30>: and.w r3, r3, r9
0x80003d0 <LoopFillZerobss+34>: str r3, [r5, #4]
0x80003d2 <LoopFillZerobss+36>: ldr r2, [r5, #12]
0x80003d4 <LoopFillZerobss+38>: movw r1, #3326 @ 0xcfe
0x80003d8 <WWDG_IRQHandler>: rbit r3, r1
0x80003dc <__libc_init_array>: clz r3, r3
0x80003e0 <__libc_init_array+4>: lsl.w r3, r3, r8
0x80003e4 <__libc_init_array+8>: movs r7, #3
0x80003e6 <__libc_init_array+10>: lsl.w r3, r7, r3
0x80003ea <__libc_init_array+14>: bic.w r3, r2, r3
0x80003ee <__libc_init_array+18>: rbit r1, r1
0x80003f2 <__libc_init_array+22>: mov.w r0, #256 @ 0x100
0x80003f6 <__libc_init_array+26>: str r3, [r5, #12]
0x80003f8 <__libc_init_array+28>: mov r1, r6
0x80003fa <__libc_init_array+30>: bl 0x8000298 <HardFault_Handler_C+60>
0x80003fe <__libc_init_array+34>: ldr r1, [r5, #12]
0x8000400 <__libc_init_array+36>: mov.w r3, #256 @ 0x100
0x8000404 <__libc_init_array+40>: rbit r2, r3
objdump generated from elf file:
8000370: f8d3 3088 ldr.w r3, [r3, #136] @ 0x88
8000374: 4a03 ldr r2, [pc, #12] @ (8000384 <SystemInit+0x50>)
8000376: f443 0370 orr.w r3, r3, #15728640 @ 0xf00000
800037a: f8c2 3088 str.w r3, [r2, #136] @ 0x88
800037e: bf00 nop
8000380: bd80 pop {r7, pc}
8000382: bf00 nop
8000384: e000ed00 and lr, r0, r0, lsl #26
08000396 <CopyDataInit>:
8000396: 58d4 ldr r4, [r2, r3]
8000398: 50c4 str r4, [r0, r3]
800039a: 3304 adds r3, #4
0800039c <LoopCopyDataInit>:
800039c: 18c4 adds r4, r0, r3
800039e: 428c cmp r4, r1
80003a0: d3f9 bcc.n 8000396 <CopyDataInit>
80003a2: 4a0b ldr r2, [pc, #44] @ (80003d0 <LoopFillZerobss+0x22>)
80003a4: 4c0b ldr r4, [pc, #44] @ (80003d4 <LoopFillZerobss+0x26>)
80003a6: 2300 movs r3, #0
80003a8: e001 b.n 80003ae <LoopFillZerobss>
080003aa <FillZerobss>:
80003aa: 6013 str r3, [r2, #0]
80003ac: 3204 adds r2, #4
080003ae <LoopFillZerobss>:
80003ae: 42a2 cmp r2, r4
80003b0: d3fb bcc.n 80003aa <FillZerobss>
80003b2: f7ff ffbf bl 8000334 <SystemInit>
80003b6: f000 f811 bl 80003dc <__libc_init_array>
80003ba: f7ff ff49 bl 8000250 <main>
80003be: 4770 bx lr
80003c0: 20020000 andcs r0, r2, r0
80003c4: 20000000 andcs r0, r0, r0
80003c8: 20000000 andcs r0, r0, r0
80003cc: 08000444 stmdaeq r0, {r2, r6, sl}
80003d0: 20000000 andcs r0, r0, r0
80003d4: 2000001c andcs r0, r0, ip, lsl r0
080003d8 <ADC_IRQHandler>:
80003d8: e7fe b.n 80003d8 <ADC_IRQHandler>
080003dc <__libc_init_array>:
80003dc: b570 push {r4, r5, r6, lr}
80003de: 4d0d ldr r5, [pc, #52] @ (8000414 <__libc_init_array+0x38>)
80003e0: 4c0d ldr r4, [pc, #52] @ (8000418 <__libc_init_array+0x3c>)
80003e2: 1b64 subs r4, r4, r5
80003e4: 10a4 asrs r4, r4, #2
80003e6: 2600 movs r6, #0
80003e8: 42a6 cmp r6, r4
80003ea: d109 bne.n 8000400 <__libc_init_array+0x24>
80003ec: 4d0b ldr r5, [pc, #44] @ (800041c <__libc_init_array+0x40>)
80003ee: 4c0c ldr r4, [pc, #48] @ (8000420 <__libc_init_array+0x44>)
80003f0: f000 f818 bl 8000424 <_init>
80003f4: 1b64 subs r4, r4, r5
80003f6: 10a4 asrs r4, r4, #2
80003f8: 2600 movs r6, #0
80003fa: 42a6 cmp r6, r4
80003fc: d105 bne.n 800040a <__libc_init_array+0x2e>
80003fe: bd70 pop {r4, r5, r6, pc}
8000400: f855 3b04 ldr.w r3, [r5], #4
8000404: 4798 blx r3
