I want to power some old machines using an USB PD power supply connected via cables containing a USB PD sink configured for the proper voltage/current.
However, one of those requires three voltages: +5V, +12V and -12V (all with a common ground obviously).
Joining the grounds of the two positive voltages does not seem like it should be a problem, however I am wary of inverting one of the 12V cables in order to generate the -12V. Is there a risk of a short circuit inside the USB PD power supply or does the USB PD standard guarantees that each plug is isolated from the others?
More precisely: would it be safe, according to the USB PD standard, to do the following:
- using three cables from the same power supply with respective voltages: A = 5V, B = 12V, C = 12V?
- connect A & B ground together with C's +12V to generate a -12V rail?
I can easily test with a simple ohmmeter if a given power supply allows it or not but I would also like to know if the standard allows for it.
