I am building a simple Tesla circuit with a 50-100 kV transformer and capacitors, discharging through a spark gap into the circuit.
Is there anything besides a spark gap that would accommodate that high a voltage discharge?
The voltage has to be that high, so please don't try to dissuade that part of it. I simply need to know if there is a component that can accommodate that high a voltage.
  • \$\begingroup\$ Neon light bulb?? \$\endgroup\$ Commented Feb 15 at 21:29
    \$\begingroup\$ You need to specify the characteristics of the device that you wish to replace the spark gap with. It would also be useful to say why I spark gap is not ideal for your requirement . Without such a specification people are liable to waste time suggesting solutions which do not match your need. \$\endgroup\$
    – Russell McMahon
    Commented Feb 15 at 21:57
  • \$\begingroup\$ Are you talking about a spark gap with a mid gap gate electrode? Please show your current circuit. Is your application a pulse radar? \$\endgroup\$
    Commented Feb 15 at 22:46
  • \$\begingroup\$ See the Popular Electronics "Big TC" (worldradiohistory.com/Archive-Poptronics/60s/64/Pop-1964-07.pdf). Very dangerous even by 1964 standards, although I had a classmate who made one and survived. \$\endgroup\$
    – John Doty
    Commented Feb 16 at 0:04
  • \$\begingroup\$ I don't understand why this was reopened; the reasons for closing have not been addressed. \$\endgroup\$ Commented Feb 20 at 22:15
There are vacuum and air and gas-filled relays that can handle higher voltages than that. They are expensive. Eg. Ross is one maker.
There are probably some hydrogen thyratrons. And stacks of semiconductors (for example, 20 5kV IGBTs) but they work with DC not HF AC.
And, of course, there is massive electrical switchgear, perhaps filled with über-greenhouse gas SF6.
If you don't care much about speed or arcing, and the current is low you could probably cob something together with a solenoid or an RC servo and contacts at the end of a G10 epoxy-glass rod or bar. I'm pretty sure I've seen some DIY items like that.
P.S. note this warning about X-rays emitted from vacuum relays in paticular: ".. over 15kV, the equipment should be shielded with lead that is at least 16 mm thick"
A hollow anode hydrogen thyratron will support both forward and reverse flows after triggering, allowing use with RF resonant circuits. However, you will still need to rectify the transformer output to DC for the capacitor charging, as the thyratron will only hold off DC of one polarity.
The more common alternative is to use a normal thyratron, but with a diode for the reverse flow.
Both options are described in the excellent E2V thyratron preamble app note.
A resistor would work... Just needs to be high voltage so you don't blow it apart:
enter image description here Source: https://www.rhopointcomponents.com/product-category/components/resistors/high-voltage-resistors/
Make sure you get the correct wattage for the power you are dumping and for the voltage rating, use more in series (like 2x 50kV to get 100kV) .
    \$\begingroup\$ He is discharging into something and may wiish the voltage to build to full level before discharging with minimal voltage drop. He hasn't said what the requirement is so it's hard to know if this will meet his need or not. \$\endgroup\$
    – Russell McMahon
    Commented Feb 15 at 22:00
