I'm currently using an Arduino Nano 33 IoT and would be powering 18 transistors - one digital pin to 1 transistor and with the use of the SDA and SCL pin to connect to 3 other I2C devices. I have run into an issue where my Nano 33 IoT will just switch off upon connecting the USB to my laptop. I suspect a power supply issue.
Is there any way I can power my Arduino to get it to output more current? I researched about the Vin pin when it can take in 7 to 21V external power supply but it seems there is a voltage regulator to regulate it back to 5V, so what is the point of using the Vin?
The 5V supplying the relay comes from the Vusb Pin of the Arduino
