I have a heater element that is controlled by a solid state relay from main power. I know it is customary to place a MOV in parallel when switching inductive loads to clamp the voltage to prevent damage when turning off the load. Is this completely unnecessary for resistive loads?
Besides that, I want to protect my circuit from voltage surges from the main so I will put a MOV anyways. I was wondering if I should get a larger MOV (more joules) to take into account the potential overvoltage from switching the heater element.
From the manufacturer, the SSR recommends putting a MOV in parallel. Considering the only inductance I have is from the copper wire which ends up being somewhere around 50 microhenries and using a zero crossing ssr, I feel like the overvoltage will be negigible but I am not sure. This will run on AC main power and 600A and my SSR is plenty overspecced. (rated to run at 1200AC but using 480AC).
