I recently ordered a GP1294AI VFD display from Aliexpress. Unfortunately it did not contain the necessary power supply to power the display, but the datasheet did include the necessary schematics for a power supply.
However, the components used in the schematic are not available from European retailers. This is why I recreated the schematic using different components. I made a few adjustments and wanted to make sure I made no mistakes before starting on the PCB layout as my power electronics knowledge is limited.
- I will use a 12V supply, so I removed the USB input connector
- I will not use the aux inputs or light sensor so these were removed
- The DCDC boost converters creating 75V and 50V were designed using the online WEBENCH tool from Texas Instruments
- The circuit from the datasheet contains a seperate SMPS for generating 3V3 from 5V. I removed this one as 3V3 is already created by a linear regulator. A high-side switch enabled/disables the filament driver instead.
All feedback appreciated!
