Is it OK to use balanced attenuator for impedance matching instead of balun? I need an attenuator anyway, so why use both?
Original schematic:
New design: skip 4:1 balun, recalculate attenuator resistors considering input impedance 200 Ohm
    \$\begingroup\$ Which side of this is supposed to be unbalanced? The source? \$\endgroup\$
    – Dave Tweed
    Commented Mar 11 at 13:43
  • \$\begingroup\$ Your schematics need a ground symbol to show where the imbalance is located. \$\endgroup\$ Commented Mar 11 at 15:15
A balun is a word composite. The first three letter (Bal) mean balanced. The last two letters (un) mean unbalanced so, when we use a balun we are converting a balanced signal to an unbalanced signal (or vice versa).
Given that you are probably using the term incorrectly (I'd call it a transformer), you are quite right that if you need attenuation then you can use a resistive impedance matching network without the transformer.
