I have recently made a High Z (1 MΩ) attenuator with R1= R3= 8.75 MΩ, and R2= 243 kΩ. I am using an LCR meter to test the impedance at higher frequencies. At frequencies above 50 kHz, the impedance is much smaller than the 1 MΩ intended value. I am using the mean sum method where Z= sqrt ((R of closed circuit) * (R of open circuit))
Keep in mind, the method I am using for calculating impedance is just a method of estimation. Moreover, I am an amateur; so please keep in mind obvious mistakes are not so obvious for me.
