So, I have a 555 Timer in Monostable Mode, like below. I used a 47uF cap and a 47K resistor for the C and R. I press the trigger switch button and let go, and the output goes high for roughly 2.5 seconds, and then goes low. Just as would be expected.
Is there a way to make it so that when I press and hold down the trigger switch, but do not release it, that it outputs 2.5 seconds, and then goes low?
And if I let go of the trigger button and press it again, it starts over again?
Image from https://www.allaboutcircuits.com/tools/555-timer-monostable-circuit/
hen's teeth
. A Schmitt input monostable will likely require a capacitive input from the switch (edge triggered) or else two 555's. \$\endgroup\$
