See, I know it might be a dumb question, but I would like an answer, however dumb it might be.
I never did any electronics before. However, I had an idea in mind that even if I can't do it right now I would want to do some day.
A calculator with updatable firmware, small internal storage and an ability for having like 3 programs you could select and each would have a different function.
Now, this is no easy task and I know that. So I wanted to know what should I learn, read and watch in order to do something like that? I know displays, buttons and many other things are needed. For the record I can code in C and alike so that I have done, I just would want to know the "hardware" side of things, because software I could probably handle fine, although I do not know how to code for such a device.
Cheers!
