I have a Camxtool v3.5 CNC controller (similar to this, although this is v3.4) that has an unmarked IC that I haven't been able to identify:
The IC is connected between pin PB3 of the ATmega328P (used as a PWM output) and a photocoupler (EL357N). The output of the photocoupler then connects to a N-channel MOSFET used to control the speed of the CNC spindle.
I also found an schematic (which I guess is not official) that shows how everything is connected, but does not identify the IC:
The schematic shows a NOT gate to negate the PWM signal before the photocoupler. Does anyone know this specific IC?
