In the LT8390, there are two sensing resistors. The one connected to LSN/LSP is called RSENSE(Buck), and the one connected to ISP/ISN is called RSENSE(BOOST). To illustrate this more clearly, I've provided a basic schematic:
My question specifically pertains to RSENSE(BOOST). Based on my understanding (which may be incorrect), there are two different methods to determine its value:
1st method:The maximum fixed voltage value around RSENSE(BOOST) is given as 100mV at full range. For example, if we want the maximum current to be 5A, this would suggest RSENSE(BOOST) to be around 20 m ohms.
2nd method:Using equations on page 20 of the datasheet:
This formula suggests that what passes through this resistor is not IOUT but rather the switch current. The switch current in boost is given by:
Thus, it suggests that RSENSE(BOOST) is calculated as 50mV (not 100 mV anymore because 50mV is in peak-boost) divided by the switch current.
I have two questions:
Which method provides the correct sensing resistor value?
If I'm only using this buck-boost as a buck (Vin=28V, Vout=20V), I'm not in a fully buck condition, but the formulas also don't make sense anymore. Saying that because delta (IL) does not make sense any more. What exactly does this sensing resistor do in this buck scenario? And how to calculate it in this scenario?
