Please help to identify Smd IC package SOT23-5 / SOT25 marking L1A1 and 2 pin is ground enter image description here
  • \$\begingroup\$ Please refer to this question for guidelines on component identification questions. Make sure to include as many details as possible including photos of surrounding circuitry and details on what the IC function might be. \$\endgroup\$ Commented May 28 at 18:51
  • \$\begingroup\$ Please clarify your specific problem or provide additional details to highlight exactly what you need. As it's currently written, it's hard to tell exactly what you're asking. \$\endgroup\$
    – Community Bot
    Commented May 28 at 19:11
Could possibly be the Anpec APL3511B USB power distribution switch. The B variant is the SOT23-5 package.
From the datasheet we have the following pinout for the SOT23-5 package, with a matching marking code. The marking codes match the variant with 2A active high enable output, and the final letter is a date code.
Pinout of IC
Marking Code L1ox where o is current limit (A) and x is date code
