I'm using my multimeter to probe a proprietary 6 pin socket on the motherboard of a PC computer that connects to 2 small 25 mm fans. The socket's pins are unlabeled. Both the motherboard and socket are non-standard, proprietary designs.
The computer's BIOS allows independent PWM control of each of these fans, and is able to show the current speed of each fan.
With the fans disconnected, I have found:
- pin 1 is ground.
- pin 2 is 12 V.
- pin 3 and 5 measure ~4.9 V
- pin 4 and 6 measure a voltage that varies between ~ 1 and 10 V as the computer boots.
From this I guess that pins 4 and 6 are the PWM pins, and the varying voltage is due to the varying PWM duty cycle.
Further, I would guess that pins 3 and 5 are the sense/tach pins, however why would I measure 4.9 V and not 0 V (because the fans are not connected)?
Is this a consequence of typical circuits used for sensing PWM PC fan speed (that the motherboard pulls the pin high to 5 V until driven low by the fan) and if so, is a “high” for the sense signal of 12 V PC fans always 5 V instead of VCC/12 V?
