To the extent that "focus" and "point" are meaningful, and for "phased array" of sufficient size:
Sure.
Waves are waves, as long as the medium is linear, they work the same, superposition applies. An optical focus is the sum of myriad waves incident from many directions, phased in such a way that they cancel out outside of the focus, and superimpose within it.
Therein lies the answer: focus below a wavelength (or fraction thereof) isn't meaningful. Focus below a fraction of the antenna aperture isn't meaningful either (that fraction being determined, in part, by the number of elements in the array), that is, the spacial/imaging resolution of the system, as defined in the usual way for optical systems.
You can't make an arbitrary E/M field in some given volume of space at any distance from an array, it can't be any sharper than the wavelength used (or, again, a modest fraction thereof).
Ultrasonic frequencies have quite short wavelength in liquid media, allowing "point" dimensions of say fractional mm; that, and converging sources from all around a patient, allows enough peak power say to ablate kidney stones or whatnot.
So on the other hand: if you wanted energy, of any given frequency, focused down to a point (in the mathematical sense, a singular location of zero width/area/volume/etc.): that's a very strong "no".
The exact phasing depends on all the reflection/refraction in the system (which is obviously quite complex in something like a patient's body, but also for applications like around-the-corner imaging), and phase and amplitude must be set so as to invert that relationship.
I don't know what nonlinearity you're referring to specifically, but the gain terms across all elements in the array need not be a straight line (or simple curve i.e. sinusoid), and in general can be just whatever.
