I've designed a BMS based on the HX-2S-JH20. The BMS design itself is clear to me, but as I want to use a 12 V DC plug for charging. The BMS takes 8.3..9 V, the circuit takes 5 V. I wasn't quite sure on how to hook this up.
I'm using 2 linear voltage regulators, both with a max input of 30 V. One outputs 9 V for the BMS to charge the cells, and the other takes the 9 V from voltage regulator 1 or the BMS and converts it to 5 V for the circuit to use (I hope :) )
Do you guys have any input on this? The part of the schematic I'm unsure about is boxed in red.
The 9 V is of course hooked up to ground, something I forgot to draw in the schematic.
