Would there be a way to replace all the functions of the good ole' cable grip (retaining the cable, providing strain relief, being watertight) with a simple overmolded strain relief ?
I am wondering if a design similar to the image below could be popped out of a hole in a plastic enclosure, would that be enough to provide water-tightness (ipx5) ?
Edit : With a carefully designed hole in the enclosure, the cable might hold in place and provide a seal (like a grommet, but with the left pad preventing the cord being pulled out). I would like to avoid fasteners if possible. (The cable will be secured at the time of installation, so I am not too much concerned about the pull-out force).
