Basic idea
Is it normal for the CMFB to output a non-zero DC level, or should it always be at 0V?
The idea behind a common-mode feedback (CMFB) circuit (elements in red in your schematic) is to generate a voltage only when both input voltages change simultaneously and in the same direction (the so-called "common mode"). When they change simultaneously but in opposite directions, the voltage should not change.
So, this voltage acts in opposition to the input common mode voltage, thereby realizing negative feedback only in common mode. This suppresses the common-mode voltage variations at the outputs of the input op-amps.
Implementation
Do the input resistors of the CMFB need to match the IA resistors, or does their relationship matter?
In your circuit of an instrumentation amplifier, this idea is implemented by an op-amp inverting summer with equal weighted inputs (equal resistors R4). Obviously, there is no dependency between the resistance of these resistors and the resistance of the instrumentation amplifier resistors. The only requirement is that they are equal (R3 = R4 in the circuit below).
Operation
Initial state
Vdiff = 0 V, Vcm = 0 V
Common mode
Imagine that Vin1 and Vin2 simultaneously increase. Their amplified replicas Vout1 and Vout2 increase with the same rate of change (the input op-amps act as followers in this mode). As a result, the common-mode feedback voltage Vcmfb (at the output of the op-amp in red) also increases. This arrangement ultimately results in the attenuation of common-mode input signals, although the specific mechanism is not explicitly depicted in the provided schematic.
Vdiff = 0 V, Vcm = 1 V
Differential mode
If the input voltages change simultaneously in opposite directions, theit sum (the voltage Vcmfb at the output of the inverting summer does not change). As a result, there is no negative feedback, and the input voltage changes are not suppressed.
Vdiff = 100 mV, Vcm = 1 V
Vdiff = -100 mV, Vcm = 1 V
About the Vcmfb voltage
What is Vcmfb?
OA1 and OA2 in common mode act as voltage followers - Vout1 = Vin1 and Vout2 = Vin2, and at the output of the inverting summer OA3, their (amplified) sum appears. So, "it is normal for the CMFB to output a non-zero DC level" (Vcmfb is not zero).
How is Vcmfb used?
To answer this question, you need to go to a lower level and look into the internal structure of the op-amp. I recommend you visit my question How do we explain the common-mode feedback in an intuitive way? and my answer to it where I have considered in detail the CMOS implementation of this clever trick. See also my answer to the question Need for common-mode feedback.
