I am working on PWM control with a Raspberry Pi Pico and came across the term "Slice," for which I am unable to find a proper definition on the internet.
A quick search gives "Slicing in pulse width modulation (PWM) refers to the ability to drive multiple PWM output signals from a single slice. For example, the RP2040 PWM block on a Raspberry Pi Pico has eight slices, each of which can drive two PWM output signals. This gives a total of 16 controllable PWM outputs."
Does a slice represent a single GPIO pin? What is a slice?
