I have a BLDC motor control PCB (custom board - 15 A peak). The requirements for that board is to have low profile (max around 15-20 mm) The chosen BLDC come with ring terminal crimp that need to be connected to "Mac8 M2 Screw Through Hole Tap" using a screw (please google the name and you'll get the full picture of the setup). We faced sometimes a loose screws due to vibration of the motor.
The purpose of this post is to check other possible method to connect the ring terminal crimp to the PCB based on all the listed requirements. If you don't have any potential idea I was thinking about using silicone, glue or solder to strengthen the connection and remove the vibration issues but I would like to have more idea about what kind of silicone I need to use or in case of repair, how I can dissolve it to access to the terminals?
Thank you.
