I am designing a PCB that will incorporate a HiLink HLK-PM01 AC-DC converter.
The only AC that will be on my PCB is the two connections between the AC pins on the HLK-PM01 and a screw terminal header that I can connect the mains cable to.
I have these two traces in one corner of the board, and there is no copper within 8mm of these traces. I believe that keeping the traces away from ground pours and any signal traces is good, however as I would also like to know if there is an effective way to connect Earth directly to the PCB?
I was considering a small copper ring around the AC traces, that is earthed, so if for whatever reason a live voltage did jump across the board, the first thing it would find would be an earthed section of copper.
While I thought this sounded sensible, I can't find anything online that shows such a technique, and that makes me think it probably isn't a good idea.
So can someone tell me if there is an effective way to earth a mains section of a PCB to increase safety and reduce potential noise?
