I'm not sure if this circuit design feasible, but i would like to have multiple voltages output coming from a single LiPo battery (3.7 - 4.2V). Initially the battery output to a switching DC-DC boost converter, higher efficiency, to a an output value of 5.5V. Then this 5.5V will distribute to various LDO, 3.3V for MCU and some ADC chip, another another LDO output 5V (for sensors). At last, another step up switching DC-DC boost converter to output 12V for signal purpose. Using LDO mainly to achieve clean regulated voltages for the MCU and the sensors.
Power Flow:
3.7V (Li-ion/LiPo) → 5.5V (Boost) → 3.3V & 5V (LDOs) : MCU & ADC IC & Sensors
from the same 5.5V (Boost) → 12V (Boost switching) : Output Signal purpose
Are there any potential issues I should consider, such as power dissipation, signal integrity, noise, thermal management? Will this drain the battery faster?
