I'm reimplementing an 80's-era controller board for which I have schematics but no gerber files; the original board has damaged traces so I'm trying to stick mostly to the original design, with modern upgrades in only a select few places.
One series of driver circuits I'm not fully understanding is this Darlington-PNP arrangement (https://arcarc.xmission.com/Pinball/PDF%20Pinball%20Misc/Williams%20System%2011b%20Schematics.pdf)
The high side of the PNPs here is driven by 18VDC. I would like to eliminate the 2W resistors here because they were a source of thermal stress on the original board, so ideally I would be replacing the entire chain after the logic gate with a single MOSFET. Other driver circuits (controlling solenoids) I've replaced with N-Channel MOSFETs with success, but I'm not sure if they're trying to accomplish some unseen voodoo here with the PNP drives - are they current-limiting the output? Are the PNPs operating in the saturated region here? These are driving incandescent lamps, so nothing fancy on the outputs (unless they're over-driving the lamps with 18V but current-limiting them?). The lamps are being used as "flashers", so are only on for ~100ms at a time.
Thanks
EDIT 1: Ok, so what about this? Again, trying to stay as true as possible to the original as far as output behavior (would like to have 18V instead of 12). A 4504 would safely translate my logic levels into the 18V range, so I can drive the FET directly, no? Or, perhaps I could change over to AND gates with open-collector outputs?
EDIT 2: Erk...I was mis-reading the schematic and thought the divider was on the source and not the gate. Now I follow. Thanks again.
