Is it possible to write EEPROM bytes via AVRDUDE and an AVRISP mkII directly from the command line without needing an EEPROM file read from another chip? Kind of like how you can specify the fuse bytes directly at the command line.
I need to be able to change a single byte of the EEPROM but would rather not mess with a file.
-U eeprom:w:0x55:m
and see if you get 0x55 in the first EEPROM byte. \$\endgroup\$
