I'm using Maxim's DS18x20 (I've actually got more than one variant) 1-Wire temperature sensors to log the temperatures in various rooms in my house once a minute. About one reading in a thousand, I get something completely bogus back. In the middle of a sequence that's gradually rising from 65F to 70F I get something like -32.1F or 15.64F.
Has anyone else had that kind of problem, or is this something wrong with my setup? If this is just a known issue with these things, I'll have to do something like taking three readings and throwing out the outlier.
Just a few statements about my setup:
- I'm running at 3.3V
- I'm checking the checksum of the reading as it comes back to the arduino, and it matches (or I think it does - there could always be a bug in that code).
- These are running off of normal power, not parasite power.
- I have the 4.7K pullup resistor in place.
- I'm only using a single sensor on each sensing platform.
- The sensor is on a PCB attached to the arduino that's reading it.
- I see the same problem reading from a variety of different arduinos (diecimilla, pro-mini, homemade custom)
