I want this circuit to give \$V_{out}\$ satisfying
\$ V_{out} = \begin{cases} -\dfrac{R_f}{R_1}V_{s1}-\dfrac{R_f}{R_2}V_{s2}; \quad \text{if} \quad \left(-\dfrac{R_f}{R_1}V_{s1}-\dfrac{R_f}{R_2}V_{s2}\right) > 0 \\ 0; \quad \text{if} \quad \left(-\dfrac{R_f}{R_1}V_{s1}-\dfrac{R_f}{R_2}V_{s2}\right) \le 0 \end{cases} \$
How do I do it?
I considered adding a diode at the output like in the image below, but I'm not sure whether it will work or not, or even if it works, it is the best way of doing it or there is a better way.
  • \$\begingroup\$ What is the load on Vout? \$\endgroup\$
    – The Photon
    Nov 14, 2013 at 2:49
  • \$\begingroup\$ An input pin of an IC, it is said to have 50M\$\Omega\$ impedance in its datasheet. \$\endgroup\$ Nov 14, 2013 at 2:57
  • \$\begingroup\$ Your proposed circuit should work pretty well then. \$\endgroup\$
    – The Photon
    Nov 14, 2013 at 3:08
There is a problem with this design since, with the series diode, there is no path for the op-amp output to sink current.
Consider the case that both inputs are positive. The effective circuit is:
Then, assuming \$V_{out}\$ is connected to a high enough impedance, we have:
\$V_{out} = \dfrac{V_{s1}R_2 + V_{s2}R_1}{R_1 + R_2} \ne 0\$
This problem is essentially due to the fact that you've lost negative feedback when the diode is reverse biased and thus, there is no virtual ground at the inverting input.
Take a look at an inverting precision rectifier to see what you need to do to fix this problem:
You can use a single supply opamp so the lowest voltage it could reach is zero.
  • \$\begingroup\$ ex: LM324 - this IC is single supply \$\endgroup\$
    – nrnw
    Apr 13, 2014 at 11:46
