I am working with an Arduino which I have a 12v power supply for, but also needs to be able to run off a NiMH/NiCAD battery pack when not connected, and recharge the battery pack when it is connected.
I have a BQ2002N IC connected as shown(actually 6 C cells, Fritzing only has AA):
When I connect the 12v power source and measure the voltage from the battery-pack to the BQ2002N, I get only ~200mv, so its not charging the battery.
When I disconnect the battery-pack and measure the voltage, I get only 2.4v (currently its 6 NiCAD cells, so it should be 7.2v if fully charged).
I haven't connected the Temperature Sensor (TS) pin yet, to keep it simple.
Does anyone at least have a good tutorial on this, I haven't found any so I'm just guessing from the datasheet.
The formula the datasheet gives for the resistors to use:
RB1/RB2 = (N-1)
here N=6
And I used: RB1 = 47 ohms (can't get 50 ohms, I assume this is close enough) RB2 = 10 ohms
