I am working on a project to count the number of cars in a specified region. I would like to use a Zibee/Xbee module. As far as I've learned, Xbee modules are used as stationary nodes and Zigbee modules are arranged in the car. There is a gateway node that receives the data in terms of RSSI values of the signal received through the stationary node.
1)How to use that data to find the position of the car?
2)A Xbee unit can take how many readings at same time?
3)What is the range of this position locator
For the first question I studied a lot on the web and there is no certain information about how to do it. All I know is a mobile node requires three stationary nodes to locate it and it is measured through RSSI value of signal received. If I am wrong somewhere please correct me.
