I have a 30Vppk signal (under 1MHz) which terminated to a 50 Ohm resistor. This is the output of the system. It can be optionally terminated by a 50 Ohm load or ** higher ** Z loads.
With 50 Ohm load the system need to push a lot of current. More of what is available from a 20 - 40 mA op amp I'll have in there. What kind of stage should be included to have unity gain without adding almost any distortion or DC offset that will be able to provide 200mA easily (transistor based I guess) ?
I also looked into paralleling op amps but I don't know if this is recommended.
