In the interval [0, 0.002], the signal has a slope of \$100/0.002= 50000\$. Then in [0.002, 0.004] its \$-50000 \$ and in [0.004, \$\infty\$] it is \$0\$.
Now let us try to represent the original signal as a sum of ramp (shifted ramp) signals. ie.,
$$ y = y_1 + y_2+y_3$$
Interval 1, [0, 0.002]: The slope is 50000 so a ramp with slope 5000 is required. So
$$y_1 = 50000t$$
Interval 2, [0.002, 0.004]: The slope here is -50000. So another ramp (\$y_2\$) starting at \$t=0.002\$ should be added here to make the slope = \$-50000\$.
$$y = 50000t+y_2$$
Taking the derivative on both sides
$$\frac{dy}{dt} = 50000 +\frac{dy_2}{dt} =-50000 $$
$$\frac{dy_2}{dt} =-100000$$
So the slope of \$y_2 = -100000\$ and
$$y_2 = -100000(t-0.002)$$
Interval 3, [0.004, \$\infty\$]: following the similar analysis,
$$y_3 = 50000(t-0.004)$$
Then,
$$y = 50000t -100000(t-0.002) + 50000(t-0.004)$$
Taking Laplace transform,
$$Y(s) = \frac{50000}{s^2}(1-2e^{-0.002s}+e^{-0.004s})\tag1$$
EDIT: Calculating Laplace transform obtained in (1)
If \$F(s)\$ is the laplace transform of \$f(t)\$, then by property of Laplace transform,
$$f(t)\Leftrightarrow F(s) $$
$$f(t-t_0)\Leftrightarrow e^{-t_0s}F(s) $$
We know that:
$$t \Leftrightarrow \frac{1}{s^2}$$
Using the property mentioned above,
$$(t-0.002) \Leftrightarrow \frac{1}{s^2}\times e^{-0.002s}$$
$$(t-0.004) \Leftrightarrow \frac{1}{s^2}\times e^{-0.004s}$$
