I've made this simple AM transmitter:
http://makerf.com/posts/fun_with_crystal_oscillators_part_3
The author of this circuit, claims that would be possible to extend the range of this transmitter by attaching a longer antenna and a better plane ground: i'm using a 10 feet of wire as antenna and a plane ground, but this transmitter is still barely able to transmit to a max distance of few inches. Why? Maybe there would be a way to amplify a little bit more the output signal, maybe using a small transistor?
Thank you.
