Suppose a cheapish lipo/18650 has a typical protection circuit in place, which, e.g., shuts off the battery when voltage gets too low, shuts off the battery when the current exceeds 4A, and prevents over-charging.
If the battery becomes old and begins to fade, and the charging device draws more current than the battery offers, could excessive heat be generated without causing an under voltage, and thus, getting through the protection circuit? Generating heat without the voltage dropping too low could be an unpreventable hazard, right?
Thanks
