I was wandering, is there some socket for ICs (memory) with SOJ packaging? I mean one that would have contacts that could go through PCB. Like some hybrid between SOJ socket SMT and DIP socket. Or can I use the second mentioned socket directly? I cannot find anything that I am describing.
edit: I am looking for some way to easily changed memory chips SOJ-36 in some socket that would be solder to PCB without SMT technology.
What you are looking for are the SOJ/PLCC socket adapters, something like this.
To be more specific.
  • \$\begingroup\$ thank you, but is there some type without the need of soldering? What I need is socket that is soldered to PCB so I can easily changed ICs in it. I edited question. \$\endgroup\$
    – benderto
    Commented Aug 14, 2015 at 10:36
  • \$\begingroup\$ Ah I get it, the answer is still yes, there is a type without soldering. I edited my comment. \$\endgroup\$ Commented Aug 14, 2015 at 10:43
