I am trying to change the STM32F407 system core clock to be 100 MHz. To do this, I need to set the source of the PLL to be HSE, and configure the PLL coefficient so as to get the right value of SYSCLK.
Here is a screenshot of the STMCube that shows the right values of PLL M, N, P, Q:
STMCube clock configuration
Here is my function
// function to configure the rc clk for running on HSE : sysclk at 100 MHz
void rcc_clk_config()
    // sysclck to 100 MHz, systick to 12.5 MHz
    RCC_PLLConfig(RCC_PLLSource_HSE, 4, 200, 4, 4);
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div4);
    RCC_PCLK2Config(RCC_HCLK_Div2);
    do {
        RCC_HSEConfig(RCC_HSE_ON);
    } while(RCC_GetFlagStatus(RCC_FLAG_HSERDY) != SET);
    do {
        RCC_PLLCmd(ENABLE);
    } while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) != SET);
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    SystemCoreClockUpdate();
In the debug session, I get SystemCoreClock = 57.600.000.
  • \$\begingroup\$ What external oscillators are on the board? Which one is connected to HSE? \$\endgroup\$
    – user16324
    Commented Dec 13, 2015 at 13:11
  • \$\begingroup\$ @BrianDrummond 8Mhz \$\endgroup\$ Commented Dec 13, 2015 at 15:18
    \$\begingroup\$ Why don't you compare with the built code from MxCube? \$\endgroup\$ Commented Dec 13, 2015 at 16:59
  • \$\begingroup\$ As Marko Buršič said: in top menu click "Project" -> "Generate code". Choose directory and there you will have a ready-to-use function which sets system clocks. If you want to write it yourself, then compare generated one with yours. \$\endgroup\$
    – zupazt3
    Commented Dec 13, 2015 at 19:42
  • \$\begingroup\$ @zupazt3 I'am working with standard peripheral library and not with the HAL library !! \$\endgroup\$ Commented Dec 14, 2015 at 0:17
It works now, here is the new code:
    RCC_DeInit();//a must
    do{
     while (!RCC_WaitForHSEStartUp());
     RCC_PLLConfig(RCC_PLLSource_HSE, 4, 200, 4, 4);//100MHZ
    do{
       RCC_PLLCmd(ENABLE);
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)!=SET);
With some experimentation and some more time reading the stm32f4xx_rcc.c, I discovered there was in fact a function: RCC_WaitForHSEStartUp(), which role is to wait for the HSE oscillator to start. I used it as follows:
do{
to replace in the previous version
do{
          RCC_HSEConfig(RCC_HSE_ON);;
          while(RCC_GetFlagStatus(RCC_FLAG_HSERDY)!=SET);
I also "had" to start the code by initializing the clock system using the function:
 RCC_DeInit();
