I'm working with this time dependent circuit, and i'm having troubles with some of the assignments. The following values are given R1 = 1kΩ, R2 = 2kΩ, R3 = 1kΩ, C1 = 22uF and C2 = 47uF. Is delivers 20mA, and when t=0 the switch goes from connected to disconnected. The circuit is stationary for t < 0 (when sure what that means?)
First of i shall calculate the current through R2, when T<0. Is it right when i assume i should use current division? Calculate the total Ω of the circuit, and divide by R2, times the 20mA?
Next, i shall calculate the voltage across C1. That one i'm uncertain about. I have found a formula V = q/C, but i can't seem to find q, the charge, or neither how to calculate what?
Lastly i shall find an expression for the current i(t) for t>0. Here i'm a little lost, so hoping for some guidance
Might be rather easy, but for a newbie, who have been introduced to all at once, its hard to find head and tail,
Hoping for help!
