I'm looking for a cheap way to monitor my electricity consumption across multiple power plugs, on a per-wire basis (ie. I'm not looking for total power consumption across all wires)
There are many commercial products I can use either at the power plug level or directly in the electrical cabinet, but they are designed to monitor a single wire, and cost usually around $15, so monitoring multiple wires skyrockets the global price quite fast, not to mention the space issue for fitting all those ammeters.
Also, I would have to use multiple clamps in a small space, and I'm not sure this wouldn't cause unwanted artifacts in the measurements.
Is there an easy way to achieve this? I was thinking it should be possible to monitor a single wire and build a circuit to switch a different power cord on that wire every second or so. Is this a stupid idea, or does it make sense?
Or are there ammeters so small and cheap that it makes sense to connect one in series with every single fuse in my electrical cabinet?
I was considering building a prototype over a 12vac supply. Am I going to run into scaling issues when upgrading to 110 or 220vac?
