I have built a prototype for a project that I'm trying to manufacture. The prototype uses an arduino, but I'm unsure how to get that produced on a larger scale. If anyone has any suggestions, please let me know. I'm really just in search of a way to get my the code that I loaded onto my arduino built into an AVR microcontroller, and how to implement that into my design. If it helps, I'm only using nine pins, and my arduino is an uno. Also, where is a good place to get boards manufactured that include sockets for microcontrollers. I havent' decided how many to manufacture yet, not until I work out this and a few more kinks.
  • \$\begingroup\$ It would be helpful if you told us how many units you plan to manufacture. Are we talking about a few hundred or hundreds of millions? \$\endgroup\$
    – JonnyBoats
    Commented Oct 16, 2011 at 20:49
  • \$\begingroup\$ possible duplicate of Pre-programming surface mount ICs \$\endgroup\$
    – Kellenjb
    Commented Oct 17, 2011 at 13:14
  • \$\begingroup\$ I don't think this question covers any ground that hasn't already been covered by previous question. \$\endgroup\$
    – Kellenjb
    Commented Oct 17, 2011 at 13:15
Usually, microcontrollers are programmed at manufacture. You supply the binary files to the assembly company and they'll flash the chips.
Some chip vendors will ship you chips pre-programmed with your image for a fee. This is likely only cost effective once you are ordering 1000s of units.
See also: Pre-programming surface mount ICs
  • \$\begingroup\$ What manufactures do this? Do you have any recommendations? \$\endgroup\$ Commented Oct 16, 2011 at 20:10
  • \$\begingroup\$ No, picking the right manufacturer will depend on your location, budget, project complexity, lead times, etc. \$\endgroup\$ Commented Oct 16, 2011 at 20:16
  • \$\begingroup\$ Do you know of any specific ones that do allow this. I'm very new to this \$\endgroup\$ Commented Oct 16, 2011 at 20:17
    \$\begingroup\$ Custom manufacturing is a huge topic. Here's a gentle introduction - make-digital.com/make/vol26/?pg=34&pm=2&u1=friend#pg34 \$\endgroup\$ Commented Oct 16, 2011 at 20:20
  • \$\begingroup\$ What manufacturer do you use? \$\endgroup\$ Commented Oct 16, 2011 at 20:34
