If you have the following circuit with a step up voltage from L1 to L2, then when do you get a spark across the spark plug? I have three scenarios.
Scenario 1. You have the switch open, then you close it right away you get a spark.
Scenario 2. You have the switch open, then you close the switch. This allows the magnetic lines of flux to expand. A current then is induced for L2. Once a little time passes you reopen the switch, and then you get a spark.
Scenario 3. Neither of these, I am dead wrong.
