I am generating a PWM at 20kHz to drive a motor. The signal goes into a motor controller which range is from 0 to 5 volts.
Since the PWM output is 3.2 volts I need to amplify it. For that I am using this optocoupler:
This is the electronic circuit I am using:
The optocouplers are inverted, pin 1 is down-right. The capacitors are 0.1uf as specified in the datasheet and the resistors are 330 ohms.
The optocoupler output is not working, it gives me less than one volt.
I already try supplying the optocouplers Vcc with an external power source, but the result is the same.
