So i ordered this cheap 100 ohm ten turn pot from ebay: Potentiometer
The problem is that it doesn't work as a normal pot (or it is broken).
When i check resistance from pin 2 to pin 3, everything is working fine, i can turn the wiper and the resistance is changing, however, if i check from pin 2 to pin 1, it shows 100 Ohms resistance all the time, no matter how much i turn the wiper. Is it supposed to do that or have i wired it wrong? Thanks!
