I am working on something that I'd like to have a backup battery source for some of the components, it's going to be on a 5V circuit, but everything that needs to be backed up should tolerate anything down to 3V fairly well.
It is all fairly low current, probably under 100ma and wont need to last all that long, so I was thinking about using a single 18650, and when I was looking into doing float charging, I saw that you could do it, if you kept the voltage on the cell low.
I went with this chip for my voltage regulator Digikey Datasheet
By using a 42 ohm 1w or 1/2w resistor, I should limit the current going into the battery to 100ma, and by putting a diode coming out of the Battery to the rest of the circuit I will prevent any accidental charging of the battery from elsewhere, is there anything I'm missing?
